JimQc
07-02-2002 10:56:25
Anyone out there know the serial number of the last 8N made prior to the NAA series ? I have sn 455555 and wonder where it fits in the list
bg
07-02-2002 11:10:20
 Re: Serial Numbers in reply to JimQc, 07-02-2002 10:56:25
Supposedly, it's 524076. I have 498459, which I reckon was made in July or August of 1952.
Jim.UT
07-02-2002 15:05:44
 Re: Re: Serial Numbers in reply to bg, 07-02-2002 11:10:20
bg,
Does your carb have a date code stamped in the brass tag area? I've seen some with and some without date codes on the carb.
Dave Smith
07-02-2002 16:03:04
 Re: Re: Re: Serial Numbers in reply to Jim.UT, 07-02-2002 15:05:44
Jim, the carb on my 48, 8N has a brass tag on it. It is marked TSX 241B, over 57,11.
Do you know what the 57 and 11 stand for? Is that a date code?
Dave <*)))><
Jim.UT
07-02-2002 16:37:43
 Re: Re: Re: Re: Serial Numbers in reply to Dave Smith, 07-02-2002 16:03:04
No, that's a new one on me. My 850 (1955) has a date code on the carb that reads "6 55" which I take to mean June 1955. After I found that I started looking on other tractors. I see a date code with regularity on hundred series carbs, but not so often on N's. When I do find one with a code, it does make sense...in other words the date on the carb coincides with the year of the tractor based on serial number....it's not like another carb from a different tractor was swapped. I don't know when they started date coding carburetors. And I really don't know what your 57,11 means.
bg
07-02-2002 15:24:47
I'll check....I don't remember 'cause it's been a long time since I've seen the carb.
Jim.UT
07-02-2002 16:33:53
 Re: Re: Re: Re: Serial Numbers in reply to bg, 07-02-2002 15:24:47
It's over there, behind that Folgers can full of nuts and washers under that pile of rags.
bg
07-02-2002 18:48:30
 Re: Re: Re: Re: Re: Serial Numbers in reply to Jim.UT, 07-02-2002 16:33:53
How did you know?
Jim.UT
07-02-2002 11:09:37
I think I saw somewhere that the last sn was around 524000.
