1953 Golden Jub 134 Block question?
Mark Hendershot
07-01-2002 15:20:31
I have this nice bare block that I was going to sell but wanted to have a machine shop mic it and hone the cylinders walls. Would it be better to leave it alone or have that done after they hot tank it? I was talking just a light hone to deat new rings on. What is the acceptable bore on a Jubilee block or what is standard bore? I wanted to feel good about this block so that is why I was going to have them do this. Any hints on what I should have them do? Mark H.
Larry NAA
07-02-2002 08:40:36
 Re: 1953 Golden Jub 134 Block question? in reply to Mark Hendershot, 07-01-2002 15:20:31
This is only somewhat related to Mark's post, but I recentely rebuilt my NAA motor. It smoked, it had very low compression and needed new pistons and rings and I decided against new sleeves. Instead, I had the old sleeves re-bored, 0.02" over, and I put in new, oversized pistons. The reason: I did try to instal one sleeve, and it went in just fine. But it got significantly out of round as a result. I can't recal exactly how much, but I think 0.008" out of round was what I saw. The New Holland shop said that was typical, and 'not really a big deal'. But for the cost of sleeves, I had it re-bored, leaving the sleeves in place, and the bores were so round I could not measure any error. At any rate, the sucker runs great now, and does not smoke at all, and has plenty of power. I also just had to take the head back off (a problem of my own creation: don't ask) and the bores looked great: no scoring or scratches, after about 60 hrs running since the rebuild. My $0.02 worth. And that's about what it's worth.
Mark Hendershot
07-02-2002 09:02:04
 Re: Re: 1953 Golden Jub 134 Block question? in reply to Larry NAA, 07-02-2002 08:40:36
Thanks Larry I will keep that in mind when they check it out. Mark H.
KB in CT
07-01-2002 19:39:11
Doesn't it have sleeves?
Mark Hendershot
07-01-2002 21:33:16
 Re: Re: 1953 Golden Jub 134 Block question? in reply to KB in CT, 07-01-2002 19:39:11
Yes it dose have sleeves but the engine ran great befor being tore down and I was just going to leave them alone. I did some checking and the bore should be 3.4375 inch and if they were in that range and not out of round I thought a light hone would be good to seat new rings and piston with. I did not want to mis/repasent the block when I sold it. But if honeing was wrong I did not want to hone it either. I figured the machine shop could check if for the specs along with the rod caps and have the block cleaned at the same time. Mark H.
