Order Ford 8N Parts Online
8N problems!
Bob
07-01-2002 07:48:58
Yesterday I decided to take my 8n for a ride down the road and I made it about a quater of a mile down the road the 8n started sputtering and died. I thought maybe out of gas but it looked like plenty was there but i turned on the reserve anyway. Tried to restart but all it would do is pop. Finally after a few moments of cranking I got it started and drove it back home and when I shut it off I heard the radiator make a gurgling sound and then a bunch of coolant came out the overflow. Then I looked down my driveway and i could see a nice stream of coolant all down the road and up my driveway. i don't understand how it could of overheated because it was only run for about 5 minutes. Does anyone have any ideas what could have gone wrong? Thanks Bob
Steve IA
07-01-2002 08:42:21
 Re: 8N problems! in reply to Bob, 07-01-2002 07:48:58
Did you top off the radiator before your ride? If you did, maybe you overfilled it and the overflow from the expansion of the coolant is what you were seeing. The overflow may have blown back on the ignition system and shorted something out causing it to stall until it dried itself out. Just my 2�. Steve 8N 169302
Bob
07-01-2002 10:54:30
 Re: Re: 8N problems! in reply to Steve IA, 07-01-2002 08:42:21
No, I didn't put any fluids in. Also I have been using the 8n to plow and brush hogg all summer and it had never done this.
Occam's Razor.. Steve IA
07-01-2002 14:33:27
 Re: Re: Re: 8N problems! in reply to Bob, 07-01-2002 10:54:30
I was hoping for something simpler than a head gasket for you. Not that replacing a head gasket is rocket science. Good luck. 8^). Steve 8N 169302
Dell (WA)
07-01-2002 07:53:55
Bob..... ....sounds like you've blown a head gasket. Pull all your sparkplugs and take a compression reading to verify. Headgasket replacement is not rocket science but be aware there is a special pattern for torqueing the 18 headbolts to 65 ft/lbs. Also while head is off, check for warp with straight edge, have it shaved at a machine shop..... .....Dell
Bob
07-01-2002 20:08:29
 Re: Re: 8N problems! in reply to Dell (WA), 07-01-2002 07:53:55
I don't understand why the head gasket could have blown because I just put this one on last summer. Today I checked the oil and coolant levels and they were fine. the 8n started right up and no smoke, but I only ran it for a few seconds because I don't want to hurt anything. thanks Bob
Dell (WA)
07-02-2002 13:39:09
 Re: Re: Re: 8N problems! in reply to Bob, 07-01-2002 20:08:29
Bob..... ..... ya never know why head gaskets blow on these low power tractor engines but they will and do if not torqued down correctly the 2nd time.
Ya gotta run a new headgasket for about 1/2-1 hr to get everything settled and streched. Then you have to re-torque the cylinder head again per the pattern..... ....Dell
