Order Ford 8N Parts Online
8N generator replacement
SteveB
06-28-2002 07:13:43
Greetings,
I recently purchased a used generator for my '48 8N (front mount distributor).
The replacement generator has an adjusting screw on the back marked "low" and "high". It seems that the screw moves the brushes in some manner. My old generator did not have this adjusting screw.
My question is, what does this screw do, and is this generator compatable with the electrical system on my tractor.
Thanks for any advice,
-Steve
SteveB
06-28-2002 22:37:45
 Re: 8N generator replacement in reply to SteveB, 06-28-2002 07:13:43
Hey Guys,
For what it's worth, this one does indeed have a 3 wire hook-up.
Thanks for all of your help,
-Steve
Dell (WA)
06-28-2002 08:56:33
Steve..... ..... ya ain't gotts the right one. take it back.
You have what is called a 3rd-brush generator for 2N/9N which is how the charge rate is determined by manually adjusting the 3rd-brush. And it has ONLY 1-wire output to roundcan cut-out relay mounted on steering column.
The frontmount 8N generator has 3-wires connected to it and has a square voltage regulator mounted on baside of the dashpanel. ..... .Dell
uh . . . Dell (WA)
06-28-2002 18:06:13
 Re: Re: 8N generator replacement in reply to Dell (WA), 06-28-2002 08:56:33
thanks for the gentle correction guys..... ...Dell
uh------bj/8n/mt
06-28-2002 10:22:40
Have a three wire generator with a high low screw on an 8n with an engine build date of Oct 15, 1948. Willing to bet it is original.
Part number 8n 10000. They should physically and electrically interchange with the later 8n 10000B although the FO 4 specs them at fewer amps.
Your mileage may vary
Chris in VA
06-28-2002 09:16:36
Dell, I have a '47 8N with a 3-wire generator that has the high-low adjust screw on it. If Steve B. has a generator with 3 wires, it might be like mine. I have never adjusted the high-low screw since the generator output seems to be set correctly for my tractor's needs. Is it possible that there was an overlap period in the early 8N's?. As near as I can tell, the generator on my tractor is original equipment. Be interested in seeing what others have, especially on the early 8N's.
Chris Fair
Spotsylvania VA
