A few questions for my NEW used block
Ken in PA
06-23-2002 07:23:02
Well asumeing the machine shop says all is well I figure I am going to need a new oil pump housing for this one and wondered if it would be a good idea to get the housing for the wider gears? I am thinking for an oil supply reason this is a no brainer but I just wanted to make sure this is a workable swap.
I figure I will need to pull all the studs out of the block so the shop has room to bore and counter bore for new .090.sleeves and figured since I have a new set of bolts I would put the head back on that way because that's the way it should be on this tractor anyway.
It does have main studs in it too and I guess I'll leave it that way? Yes? No? Why?
Thanks,
Ken
Scott
06-23-2002 18:33:34
 Re: A few questions for my NEW used block in reply to Ken in PA, 06-23-2002 07:23:02
Remember when you go with the wider pump you must use the shorter oil pickup tube, also make sure your drain plug has the screen on it.
Dell (WA)
06-23-2002 08:50:20
Ken..... .....I once saw a Ford Service Bulletin saying that headbolts were approved for replacement use in N-Blocks, the factory would not pay for it. Check with Don about the desirablility of using stronger headbolts over your current studnuts. Go for the bigger oil pump..... ...Dell
Ken
06-23-2002 14:58:28
 Re: Re: A few questions for my NEW used block in reply to Dave Smith, 06-23-2002 08:06:08
Heck no that price was great! Just can't pay what you don't have and I have slowly built up some parts for this one so I have a cut crank and brngs ready to go and the heads been checked. Also have the cam timing stuff and most of the valvetrain parts.
If I could have the thing to do would have been to buy the re-build and ebay all that I have..... .may have about paid for it!
Ken
yabutt . . . Dell (WA)
06-23-2002 17:28:49
 Re: Re: Re: A few questions for my NEW used block in reply to Ken, 06-23-2002 14:58:28
Ken..... ..think of the eduication you're getting doing your own mechanicanicing..... ...Dell
Ken
06-23-2002 20:30:05
 Re: Re: Re: Re: A few questions for my NEW used block in reply to yabutt . . . Dell (WA), 06-23-2002 17:28:49
Well thebig thing is that I'll know just what I have when I'm done. If I would have bought the re-built motor I would have had to dig into it to switch parts for the front mount and knowing me I would have pulled the whole thing down and found 50 things I didn't like.
Plus this way I can help support my local machinist! Let's see here line bore, cyl bore, mag test, grind seats, hot tank.
I REALLY like this shop and I know the job will be handled right and I do very clean and thorough assy work so I should have another 50 years in this old girl!
Ken
