Yep, on my Yahoo account (mikesw200@yahoo.com) I get about 3 hits a day. I use it only for this board and the Dodge Power Wagon board and have received infected messages that look like they come from both. BTW, I received one the other day with your address as the spoofed return address, so it is someone with our addresses in their address book. Just in case someone is unfamiliar with how K L E Z works, here is the info from the SARC site. Email spoofing This worm often uses a technique known as "spoofing." When it performs its email routine. it can use a randomly chosen address that it finds on an infected computer as the "From:" address, numerous cases have been reported in which users of uninfected computers received complaints that they sent an infected message to someone else.
For example, Linda Anderson is using a computer that is infected with W32.Klez.H@mm. Linda is not using a antivirus program or does not have current virus definitions. When W32.Klez.H@mm performs its emailing routine, it finds the email address of Harold Logan. It inserts Harold's email address into the "From:" portion of an infected message that it then sends to Janet Bishop. Janet then contacts Harold and complains that he sent her an infected message, but when Harold scans his computer, Norton AntiVirus does not find anything--as would be expected--because his computer is not infected. If you are using a current version of Norton AntiVirus and have the most recent virus definitions, and a full system scan with Norton AntiVirus set to scan all files does not find anything, you can be confident that your computer is not infected with this worm. There have been several reports that, in some cases, if you receive a message that the virus has sent using its own SMTP engine, the message appears to be a "postmaster bounce message" from your own domain. For example, if your email address is jsmith@anyplace.com, you could receive a message that appears to be from postmaster@anyplace.com, indicating that you attempted to send email and the attempt failed. If this is the false message that is sent by the virus, the attachment includes the virus itself. Of course, such attachments should not be opened. The message may be disguised as an immunity tool. One version of this false message is as follows: K l e z.E is the most common world-wide spreading worm. It's very dangerous by corrupting your files. Because of its very smart stealth and anti-anti-virus technic,most common AV software can't detect or clean it.We developed this free immunity tool to defeat the malicious virus. You only need to run this tool once,and then K l e z will never come into your PC. NOTE: Because this tool acts as a fake K l e z to fool the real worm,some AV monitor maybe cry when you run it. If so,Ignore the warning,and select 'continue'. If you have any question,please mail to me.
