2N Rear Axel Trumpet Gaskets
george
06-18-2002 09:18:15
First let me say "thank you" for all of the helpful advice I have received to date. Many replies go un-acknowledged.
I have cleaned-up and installed the axle trumpets to the rear housing, replaced the brake pads, and preparing to install sure-seals on the rear axles. When I removed the axels and brake drums, there was a gasket and a shim on the left side and a gasket only on the right side. Neither item is shown in my parts manual. Are these required and if so, any part numbers?
Jay 2NSC
06-19-2002 18:49:49
 Re: 2N Rear Axel Trumpet Gaskets in reply to george, 06-18-2002 09:18:15
Hi George,part's manual give's the # as 2N-4035 for the gasket,center housing to rear axle housing,2N.HTH,Jay 2NSC
george
06-24-2002 07:01:01
 Re: Re: 2N Rear Axel Trumpet Gaskets in reply to Jay 2NSC, 06-19-2002 18:49:49
Jay:
Thank you, although I did obtain and install the trumpet to housing gaskets. It's the drum to trumpet gaskets and shims that I am questioning.
