3 pt dropping.
Steve IA
06-15-2002 10:37:58
Yesterday, while transporting the BH to the farm about a mile away, I raised it about 3/4 maximum and shut off the PTO. I only raised it that high as the PTO shaft was gonna hit the front of the BH if I went higher. About 1/2 mile down the road I hear the back wheel of the mower bouncing off the gravel. By the time I got to the field the front was down quite a bit too. This morning I'm up early, disconnected the PTO shaft to the BH lifted it up to the top and pulled the inspection plate looking for cylinder leaks or blown gasket or whatever. Saw nothing other than a very slow drip from the cylinder which I considered normal. When I shut the pump off, I did see a stream of very tiny bubbles coming from the right front of the hydraulic area between the pump case and the side of the tractor. I had just minimal drop down of the BH while I watched. 2 Questions: Will the hyrdaulics hold better at full up rather than at say 3/4 of the way up? Mine seemed to. Can the stream of bubbles be coming from the bottom of the oil tube that transports the fluid to the cylinder from the pump? How is this tube seated in the pump? My I&T F0-4 doesn't really show much about the tube. There are 3 kinds of people in this world. Those who can count and those who can't.
Thanks for any comments. Steve 8N 169302
ZANE
06-15-2002 18:36:02
 Re: 3 pt dropping. in reply to Steve IA, 06-15-2002 10:37:58
It is quiet common for the lift to drift down after the PTO has been disengaged. That little leak from the piston can do it.
The pump is sealed at the bottom of the differential housing by nothing more than a gasket. This gasket does not normally leak. It can blow out either inside or outside but when it does you got almost no lift.
What you really would like is my LIVE THANG (live hydraulics) for the N tractor. With it you can disengage the PTO and cycle the lift up and down as many times as you want to without the pump in the belly even moving.
BELIEVE IT OR DON'T!
See my web site at the link below.
