Order Ford 9N Parts Online
1940 9n problem
wayne n.c
06-12-2002 16:38:01
draind tank , new fuel bowl assembly. new maniafol, new carb. new gas. starts great and idles smooth but no power. carb ajustment no change. no leaks around intake man. grateful for any help.
Dell (WA)
06-12-2002 20:14:33
 Re: 1940 9n problem in reply to wayne n.c, 06-12-2002 16:38:01
Wayne..... ....engine power is determined by igntion time. Frontmount distributors can get their centrifical advance weights hung up, specially if wrong (too long) points or condenser screw gets accidentally used. Should be #8 X 3/16 long. Longtime ago, one of the founding contributors to the N-Board claimed that 80% of all carb problems were found in the ignition system. Something to think about..... ....Dell
big Dan
06-12-2002 19:17:11
you might want to check the governer. If it starts good and idles take the throttle arm and see if it revs up ok.If it does and everything is still running smooth I would check the governor.Also check your air cleaner,unhook it at the carb and see if that makes any difference,especially the air screen at the top they have a tendency to really get blocked up.Hope this helps
bg
06-12-2002 17:30:51
I'd take the carb apart and run some heavy moifilament or a piece of wire inside all o fthe little passeages, spray in carb cleaner, blow out with compressed air.
