1944
2N lost oil pressure
JWB
06-11-2002 10:33:23
My 2N lost oil pressure. Gauge works. Is there any other obvious oil pressure problems that need to be checked out before I get to the serious break down.
pressure wash . . . Dell (WA)
06-11-2002 11:58:07
 Re: 1944 - 2N lost oil pressure in reply to JWB, 06-11-2002 10:33:23
I think you're there. Give it a pressure wash so you can remove the front axle so you can remove the oil pan so you can remove your broken oil pump pick-up. Sometimes you get lucky and haven't burned your bearings, but I'd at least check some. Good luck..... ....Dell
