Lesson Learned on PTO Maintenance
Mark in Central
06-11-2002 10:20:50
Just thought I would pass on a word to anyone else who might not think about PTO Shaft maintenance on a mower. This is my third summer with the 52 8N and 6' King Kutter finish mower. I didn't think about greasing the 2 halves of the PTO shaft on the mower. They rusted together pretty tight. Ended up connecting the two ends to chains and after much effort we managed to pull them apart with a little help from some machinery. Thought I was going to have to buy new - but it worked out. Had to grind down the rusted areas on the outside inner tube and use a file on the inside of the outer tube. Took a while but it's sliding free and smooth now.
kjm
06-12-2002 08:39:48
 Re: Lesson Learned on PTO Maintenance in reply to Mark in Central Ohio , 06-11-2002 10:20:50
Grease is cheap, parts are not. My Dad said so!
Grease every zerk you can see
06-11-2002 11:18:24
Before each use! Your equipment with reward you with many more years of service. (drilled into my head by my dad) :-)
Arne
