6volt coil,help me MR.Dell
Drmeatman
06-09-2002 13:46:47
When I purchased this little 2n it (was)a 12v conversion front mount dis.I'm hoping to return it to 6v.and upon inspection I can't tell if coil is 6v or 12v.ONLY TIAWAN dangit.Give me directions THANKS.
Jim WI
06-10-2002 11:09:59
 Re: 6volt coil,help me MR.Dell in reply to Drmeatman, 06-09-2002 13:46:47
You could always buy a new 6V coil -- they're not that expensive.
Then again, I wouldn't change it back if the 12v system is working right unless there's something special about that 2N that would raise some collector interest.
Dell (WA)
06-09-2002 14:09:40
Uh..... ....do you really want to go backward and try to find all the 6 volt generator stuff and brackets. Do you really understand what it takes to re-wire back to OEM 6 volt configuration?
UNFORTUNATELY, they don't lable those frontmount ignition coils whether 6 or 12 volts so its kinda a technical thing to make an educated guess. An ohmmeter will give you an indication by measuring the primary winding resistance.
An OEM 6 volt frontmount coil primary will measure about 1 ohm. The newer 12 volt frontmount primary will measure about 5 ohms. Exact value is NOT critical because the difference is about factor of 5 which is a major difference in electricity talk.
BTW, the secondary sparkies winding will generally be about 5000 to 10000 ohms, again a major difference compared to the primary winding resistance.
Personally, I'd leave your 2N converted to 12 volts unless you have a really compelling reason to retro-vert back to 6 volts.
I'm a 12 volt advocate for the right reasons, that said, I haven't found the right reason for my eazy starting 52 8N, and I know how to do it right..... .....Dell
tl
06-09-2002 17:53:51
 Re: Re: 6volt coil,help me MR.Dell in reply to Dell (WA), 06-09-2002 14:09:40
Dell, I think everyone knows by now you can convert a 6 volt to twelve volt, and do it right.
You have only mentioned it about 50 times. Who cares?
Drmeatman
06-09-2002 19:56:34
 Re: Re: Re: 6volt coil,help me MR.Dell in reply to tl, 06-09-2002 17:53:51
Thanhs DEll,Idon't understand a word you gave(grin) but I REALLY do want to get it back to the way Mr.Ford sold it.I'll probably have to get a pro. to come do it for me.I have a problem changing bulbs in a lamp.My 38yrs. doing surgery doesn't qualify me for anything, dangit.Thanks Buddy
