Installed new manifold today BUT....
Curt in KS
06-06-2002 14:23:10
Installed a new intake/exhaust manifold on my '48 8N today, but when I finally got it to run (after having to pull start it) it won't hardly run. Kinda runs with the choke out, sorta. Any ideas? It was running fine before I put the new manifold on.
Thanks for the help.
Curt
Scott
06-06-2002 15:57:24
 Re: installed new manifold today BUT.... in reply to Curt in KS, 06-06-2002 14:23:10
Did you get an aftermarket or original (Ford) New Holland manifold? some aftermarkets like the one Central Tractor sold is very rough inside and engines do not run as smooth as before. Did the nuts thread on ok?
MikeC
06-06-2002 14:44:22
I have to suspect that your gasket is not sealing well. One test is to spray some WD40 around the edge of the manifold and see if it smooths out.
curt in ks
06-06-2002 19:50:26
 Re: Re: installed new manifold today BUT.... in reply to MikeC, 06-06-2002 14:44:22
thanks for the replies. talked to the dealer I got it from and he thought that it maybe wasn't cast correctly. took it back off and put the old (cracked) one back on and it fired right up
