Order Ford 8N Parts Online
49 8N oil drain nut
Jeff
06-06-2002 10:13:48
I can't get it off. Should I turn it counter clock wise (lefty loosey)?
Thanks for the info on how to install the distributor tune up kit. I didn't even need to use a hammer!
Fessman
06-06-2002 19:17:34
 Re: 49 8N oil drain nut in reply to Jeff, 06-06-2002 10:13:48
Jeff,
I've got one of these drain plugs on the transmission. Someone suggested putting a pipe wrench on it, with a cheater bar. Then place a jack and a board under it, and apply enough pressure with the jack so that the wrench does not slip off the nut. Then turn the nut. Sounds easy, but I have not tried it yet. Good luck
Fessman
Mark Hendershot
06-06-2002 22:57:18
 Re: Re: 49 8N oil drain nut in reply to Fessman, 06-06-2002 19:17:34
That was my idea and it should work. If you can do it befor you slip so much that you strip it round. Tap the wrench with a hammer to knock it loose. Mark H.
Ron
06-06-2002 16:40:52
There is a good chance that someone may have put a little gasket sealer on it. I had the same problem once and sure enough someone put just enough gasket sealer on it to keep it from coming off. Try putting a little heat on it from a tourch to warm it up just enough to melt the sealer. Not too much heat to make it a fire hazard,just enough heat to loosen the sealer.
Good luck.
Mark Hendershot
06-06-2002 10:45:01
Counter Clockwise just like a regular bolt would turn to remove it. Mark H.
Eric - Ky
06-06-2002 10:30:22
Lefty Lossey. Changed mine last night.
