Order Ford 8N Parts Online
49 8n tune up kit
Jeff Brown
06-05-2002 10:13:48
Is there a trick to installing the distributor parts? Not much room between back of radiator and distributor.
...and it's $29 (cheap)
06-05-2002 15:11:50
 Re: 49 8n tune up kit in reply to Jeff Brown, 06-05-2002 10:13:48
...for the FO-4 I&T shop manual.
Grin,
Tyman
yep . . . Dell (WA)
06-05-2002 10:24:37
Jeff..... ...every newbie gets bit by the same situatition. (grin)
Believe it or not, 2 bolts and you take the distributor off and out the tractor to the workbench and replace and time the points per the I&T FO-4 manual. (how-to picture is worth 1000 words)
The distributor drive is "offset" so it only fits one way (unless you use a really big hammer)..... ...Dell
Salmoneye
06-05-2002 10:21:48
2 1/2 inch hex head bolts and the distributor is in your hand.
Note rotor direction and replace in the same direction.
Tang on the rear of distributor is offset to make incorrect replacement REALLY difficult.
Get yourself an I&T FO-4 shop manual.
Will save you the $30 it costs in frustration, confusion and time the first time you read it...
Fast Ed Ohio
06-05-2002 21:33:39
 Re: Re: 49 8n tune up kit in reply to Salmoneye, 06-05-2002 10:21:48
I think 7/16 wrench will work better, but I have been wrong before .
I stand corrected...
06-06-2002 02:30:20
 Re: Re: Re: 49 8n tune up kit in reply to Fast Ed Ohio, 06-05-2002 21:33:39
I was in a hurry and mispoke.
Thanks for the good catch!
