Level a Bush Hog
Bob Persse
06-02-2002 19:31:11
Got a '49 8N with a King Kutter hog. I know I'm going to stamp stupid on my forehead, but how do I get to level this thing so the front of the unit dosen't dig into the ground? First off the unit is attached with a 3pt hitch, solid variable toplink, and rigid lower arms. This hog has a swing U attachment for the toplink, which dosen't allow me to extend the toplink so that I could use the leveling device on the tractor. Any help will be appreciated.
Bob P.
06-03-2002 08:48:11
 Re: Level a Bush Hog in reply to Bob Persse, 06-02-2002 19:31:11
Thanks to all of you for your replys. Will give each one consideration.
Best Regards,
Bob Persse
Marcellus, NY
ZANE
06-03-2002 05:03:06
That is what the position control is for on the 8N lift. You must have the little lever under the seat in the up (vert.) position in order for the height of the lift arms to be set in position and stay there. If it won't hold the lift arms at the height that you select then the lift needs to be repaired and re-adjusted.
See the link below
Ed Gooding (VA)
06-03-2002 02:57:19
Hi Bob. Here's what Allen is talking about:
third party image
You can buy these at any tractor supply place. If you have some ¼" chain laying around, I have some plans from another forum member to make you own. I can post if you want them.
Hope this helps..... ..... Ed
'52 8N475798
Ultradog MN
06-03-2002 06:10:03
 Re: Re: Level a Bush Hog in reply to Ed Gooding (VA), 06-03-2002 02:57:19
I was looking for some limiter chains this weekend
to keep the drawbar up while I was pulling the grader.
Didn't have the tools etc to make a set while I was at the lake so I went in to town to see what I could find.
The FNH dealer had never heard of such a thing
even though he said it was a clever idea.
Then I went to the local welding shop to see about buying a couple of small shackles that might work
just to get by for the weekend. The older guy there had seen limiter chains before, even made some for people.
He used a term I wasn't familiar with.
Called the plates with a notched hole for the chain a "bitch link".
Odd. Still, it works for me.
Thanks Ed. I didn't know they were comercially made. Was going to get out the drills, saws, torch etc and make a set. But I'm going to have a look at Fleet Farm before I start.
Or call the # on the picture you posted.
Sometimes you can't build a set for what you can buy them.
Ed Gooding (VA)
06-03-2002 09:55:14
 Re: Re: Re: Level a Bush Hog in reply to Ultradog MN, 06-03-2002 06:10:03
yeah, I think V@lu-Bilt sells them for about $17.95 a set. Not worth making your own unless you happen to have spare chain laying around, or you just like to make your own stuff. If you want to make your own, here are plans and two drawings from forum member Marshel Rossow:
Limiter chains for three-point hitch
These chains are simple to make. The materials you will need are:
- Two 40-inch lengths of 1/4-inch chain. You probably could get by with two 36-inch chains. The chains could also be heavier, but there's no reason unless you have some chain lying around and want to use it.
-Four pieces of flat 1/4-inch steel, each piece measuring 2 inches wide by 3-1/4 inches long. Length and width could vary slightly. Tools you will need: -Drill press with 7/8-inch bit. -Welder. -Hacksaw. -Rat-tail file. (If lacking the oversize bit and a welder, you could get by with a half-inch drill with 1/2-inch bit and the rat-tail file. It's a bit of work, but you could file the holes open to the necessary size.) To make the chains: (1) Drill 7/8-inch holes in the four metal tabs as shown on the accompanying sketch -- two holes in each top tab, one hole in each bottom tab. Make sure your top-link pin will go through the holes. If not, use the rat-tail file to enlarge the holes slightly. I drilled the 7/8's holes in the bracket for the chain limiters with an electricians hole saw. It is made for the outside dimension of a 1/2" emt connector and it measures 7/8's OD. It worked like a champ. Be sure to use a good cutting oil or that metal will burn up the hole saw. (2) In the bottom hole of the top tab, cut a 1/4-inch-wide slot about 5/8-inch deep as shown on the sketch. You can cut the slot by taking the blade out of your hacksaw, sliding it through the hole and reattaching it to the saw. When finished, you should be able to slide the 1/4-inch chain through the hole and drop any link into the slot; that's how you adjust the length of the chain. If the chain won't slide through the hole or drop into the slot, do some filing to enlarge the hole and/or slot. (3) Weld the bottom tab onto one end of each piece of chain, as shown. If you don't want to weld, drill a half-inch hole toward the top of the two bottom tabs and bolt them to the chains. That's all there is to it. Attach the chains to the tractor and implement as shown in the sketches. To adjust the length of the chains (which in turn will determine how far down the lift arms can go), lift the implement with the hydraulic system, then pull the chains through the top tabs and slide a link into the slot. Make sure each chain is adjusted the same length or you'll have all the weight of the implement riding on only one of them. It will take some trial and error to determine the best working length for the chains. Once I found the proper length, I painted the links that go into the slots so I didn't have to go through the experiment each time I used them. Once the chains are in place and the implement mounted, you can lift as high as you want, but if you must go lower than the chains will allow, you'll have to readjust their length. You may find that you have to get a longer top-link pin to fit through the top tabs. You can find longer pins at farm-supply stores, or you can make your own out of 3/4-inch or 7/8-inch round stock from a hardware store. If anything I've explained here isn't clear, be in touch and I'll try to clarify. Good luck with this project. Marshel Rossow LIMITER-CHAIN ADDENDUM: If you're using these chains in conjunction with drawbar stabilizers, you're likely to run out of room on the implement lift pins for the chain tabs. (This will be true whether you make your own or buy the chains.) What I did was bolt the tabs directly to my mower deck, using the same big bolts that hold the top-link arm to the deck. (I'm not sure about the technical name for this arm -- on my mower it's like a big, upside-down Y that bolts to two tabs on the deck, and the top link between tractor and mower attaches with a pin at the top end of the upside-down Y.) Regardless of your mower, you can probably find a logical place to attach the chain tabs somewhere at the front of the mower framework. At worst, you might have to drill a couple of half-inch holes. The only inconvenience is that if you want to use the chains on some other implement, you have to unbolt them. But it's the mower decks that really need the chains. Besides, once you've made one pair, you can make others for additional implements as needed.
third party image
third party image
Hope this helps..... ..... .Ed
'52 8N475798
allen
06-02-2002 20:56:59
Bob , I level all all of my three point bush hogs by using chains.Bolt or weld a chain at the bottom of A-frame on each side of bush hog.Then take 2 pieces of 1/4 x 2 flat iron,drill a hole in one end to fit top link pin.Drill a small hole in the opposite end to attach a grab hook.Use a longer top link pin by inserting it first through one piece,then through top link and bracket,then the last piece and insert lynch pin.Chain will pass between lift arm and pto shaft up to sides of top link bracket.Raise hog all the way up to get slack to adjust length of chain.This set up keeps hog from digging in ground especially when turning.For safety unhook pto shaft while adjusting chain length.LOL
