Jubilee Starter Problem
Brian
05-31-2002 08:12:00
My 8N recently stopped cranking during start-up. The solenoid clicks, but no start. I have checked the voltage at the starter and it is 12+ volts when crank switch is pushed. I removed the starter and applied battery power to it and it spins during contact. If I hold onto the starter shaft with slight pressure, it will stop. Does this indicate that the starter is bad or is the starter drive doing its job?
Dell (WA)
05-31-2002 08:39:53
 Re: Jubilee Starter Problem in reply to Brian, 05-31-2002 08:12:00
Brian..... ....any starter motor I've ever spun out on the bench, I'd never touch the starter shaft because it has so much spinning power. NO WAY!!! good way to loose hand.
Bottom line, if you in you foolishness, can stop your starter shaft, I'd say you've got a BAD STARTER MOTOR..... ..... Dell
Dan
05-31-2002 18:35:03
 Re: Re: Jubilee Starter Problem in reply to Dell (WA), 05-31-2002 08:39:53
I suggest --- check / change the brushes , and internal connections .
