2N or not 2N??
Eb
05-30-2002 21:25:11
My wife and I obtained some property with about 5 acres to mow.. Originally I was considering getting an decent size garden tractor (JD or Cub Cadet) to do the mowing....Well after surfing the web I came across several sites dedicated to the N and the fanatics that own them...(Thanks guy's now you got me sucked into the whole N cult!)
Well back to my question...Today I took a look at a 45 2N..Sheetmetal was good, engine started right up, no noise, no smoke, no oil leaks, no leak down in the hydraulics, new wiring, OD tranny. Will this machine and a 5 or 6' finish mower take care of 5 acres of grass/weeds with some gentle slopes?..I will probably want to do some snow plowing also...
Am I looking at the right tractor or do I need to be re-programmed.....
Danny in CO
05-31-2002 09:21:21
 Re: 2N or not 2N?? in reply to Eb, 05-30-2002 21:25:11
Eb,
I have 13.5 acres here is Colorado. When I first bought the property in 1994, I bought an 18HP Sears Lawn tractor with a 44" mower deck and spent around $2000. I have about 5 acres I keep mowed. With the Sears tractor, it would take many hours to mow the 5 acres. It is not really big enough to use for snow removal. You can buy blades and snow blowers for it, but it would not handle a deep snow.
2 years ago, I decided I needed something bigger. I looked at all kinds of older tractors. For several reasons I decided an N was what I wanted. I bought a 48 8N with post hole digger, box blade, back blade, 6' mower deck, front end loader, and tires chains. All of the implements were new except for the FEL. I gave $3500 for all of it. It now take about 2.5 hours to mow the 5 acres, plus I can remove snow, grade, dig post holes, ...
I still use the Sears for trimming around trees, but the N is MUCH more tractor for the money. As others have said, you will have more maintenance, but it's not hard to maintain.
My $.02 worth,
Danny
Mark Hendershot
05-31-2002 06:27:01
third party image
Well take a look at the picture of what you can do to one. This is a 1942-9N tractor. Now this is a 60 year old tractor!! Compare it to a Cadet Mower. Which would you prefur to use mowing your place and say 5 or 6 years later which would be worth more? They are about the same cost if not cheaper. Mark H.
Mark H. 1980 Cub Cadet 782 Nice One
05-31-2002 06:35:46
 Re: Re: 2N or not 2N?? in reply to Mark Hendershot, 05-31-2002 06:27:01
third party image
Here is a Nice 1980 Cub Cadet restored and he did a good job on it. The newer Cadets are not built as good now. Hope this help in your desion. Mark H.
MikeC
05-31-2002 04:38:00
You will be much happier with an N as long as you are willing to invest the time in routine maintenance. If not, I recommend a garden tractor and scrapping it every few years for a new one. BTW-as a kid I don't particularly remember any of the "lawn mowers" that Dad had, but I have some great memories of the farm tractors such as the N's, an NAA, D15, D17, WD, G,...you get the picture.
ZANE
05-31-2002 04:28:02
What do you think the little bitty yuppy lawn tractors with those little bitty aluminum engines will be doing 50 year from now?????
They will be beer cans!
That N will probably still be cutting grass and pushing snow if we are still taking the oil away from the arabs to run them on. Other wise they will still be better for making gun implacements than the little bitty yuppy yard tractors. Hunks of cast iron turn bullets good! They go right through beer cans!
Besides now you can modify the N tractors to have almost the same options as the later model tractors. Position control of the lift. Live hydraulics. Lights and mud flaps! Radio? Cup holders! Seat cushions with backs on them. Talk about luxury!
Do about four times the work as that yuppy thing and for about a forth the price and if you happen to run over a beer can it won't turn you over.
Zane
Ultradog MN
05-31-2002 03:51:39
Eb,
Coming to this site to ask if a 2N will serve
your needs is a little like going to Mecca and asking if Mohammed was a profit. As Dell said
an N wont be quite as reliable as a brand new garden tractor. But it will still be around after you've worn out 4 or 5 of them 'reliable' ones.
So far we've just talked about mowing. But don't forget about all the plowing, discing, bush hogging, post hole digging, back blading, planting, cultivating, hay riding, parading, excavating etc. There were something like 300 attachments you could put on an N...
Get the 6' finish mower btw, and a 5' rotary (bush hog)
Good Luck and welcome to Mecca the Ayatolla
er...
Ultradog
Big Mike
05-30-2002 22:17:52
The other link
Dell (WA)
05-30-2002 22:16:38
Eb..... ..... Would hate to give you a "bum steer" but you're looking at in my opinion about 3-times the unit as JD garden tractor. The only thing they really have in common is 4 wheels and a seat. A 2N will do your 5 acres in about 1/3 the time that a Cadet will.
The down side (you knew that was coming), 60 yo 2N will not be as reliable as this years garden tractor, but in 5 yrs will your gardentoy be reliable? Great thing about 2N's, parts are readily available and reasonablely priced. BUT you really want to be able to turn the wrenches yourself, otherwize, GO with the $500/mo payments.
Remember, N-tractors were designed for horse farmer and bailing wire repair. Today we have ducttape and superglue (grin) and I&T FO-4 manual ($29 cheap). If you can read, you can do all the necessary N-Repairs..... .....Dell
Phred MN
05-31-2002 11:50:51
 Re: Re: 2N or not 2N?? in reply to Dell (WA), 05-30-2002 22:16:38
Eb, you may need both. My wife did'nt like my 8n cause she's afraid of it or something so she went out and bought a Cub. If you get the Cub too, get the hydro drive. Well thats fine cause now I get to play landscaper with the 8n while she mows.. Get both!! Yahooo
Big Mike
05-30-2002 22:15:40
You are on the right track. Unless you really enjoy mowing the garden tractors are too small in my opinion. I mow my Sisters field with a 8n and a 5 foot finish mower the field is three times bigger than the lawn around the house.I Use a 38 inch? craftsman for the lawn and both take the same amount of time. The N should handle a 6 foot finish mower. Rear discharge models seem to get good press here. My deck is side discharge and likes to plug up if the grass is too tall or too wet.If you are not in a big hurry look around some at the later ford tractors these are known as the jubilee/naa and the hundred series. These are the improved version of the N-series . They came with live hydraulics (the ability to raise implement with out needing the pto engaged and spinning. Check out these two sites for lotsa info on ford tractors.. http://members.aol.com/naa60512/naa.htm
