Order Ford 9N Parts Online
9n ignition
Bones
11-20-2000 14:12:17
I have the engine out, and need a kit to convert the ignition system to a breakerless system. Surely I can find a way. Someone out there has a solution...i just know it!!!I can do some "rigging" if need be to have the thing work!!! Help!!!
Ron from IL
11-20-2000 15:11:41
 Re: 9n ignition in reply to Bones, 11-20-2000 14:12:17
Bones,
If yer a mind to cobble, contact Genesee Products. They will help you with the 'correct' igniter and magnetic ring, although you'll have to have some minor machining done to the distributor shaft and the mag. ring. Check out the summer issue of N-Newsletter. There's just such an article.
Ron
Claus
11-20-2000 14:28:03
The problem with the Front Mount Distributor is that the front bushing is supported with a top hat shaped bracket. There is not enough room for the reluctor (Genesee calls it a doughnut) to fit over the cam, since the sides of the bracket are close to the cam. You would have to do a little redesign of the distributor.. There are kits that will allow you to use the current breaker points to switch transistors so that the transistors take the heavy current and not the points. This would extend point life almost indefinately.
Happy Motoring
Claus
Bones
11-21-2000 17:29:31
 Re: Re: 9n ignition in reply to Claus, 11-20-2000 14:28:03
Claus; thanks. i think i understand somewhat. would it take lowering the bushing, or leaving the reluctor a bit high? If left high, can that work if i also shim up to the same height the pickup? That way they could stay aligned???
