Jubilee still dies when on a slope.
Terry-N-Mo
05-28-2002 12:30:02
Was out mowing today and as soon as i tried to mow the ditch out next to the road it puttered and died. Yes i did check the gas and it was 3/4 of a tank.It only does it when sloped to the left. I turned around and went the opposite direction and it ran fine.Could this be a sediment bowl or maybe a float problem? Any other suggestions is welcome. Thanks,Terry
Walt Mo
05-29-2002 09:25:13
 Re: Jubilee still dies when on a slope. in reply to Terry-N-Mo, 05-28-2002 12:30:02
I had the same thing, also would not use all the gas in the tank. I found the holes were pluged at the bottom of the feeder tube in the gas tank. These holes feed gas when the gas valve is completly open. If the holes are pluged you can run out of gas with 2-3 gallons in the tank when on a slope.
BigAWB
05-29-2002 05:16:08
Danny my Jubilee will do the same thing. The fuel feed from the tank is on the right side of my tank. I simply run out of gas if tilted to far to the left.
Al (NC)
05-29-2002 06:47:36
 Re: Re: Jubilee still dies when on a slope. in reply to BigAWB, 05-29-2002 05:16:08
Ditto
Danny in CO
05-28-2002 12:37:22
My guess is that it is a float problem.
Danny
