Jubilee rear rims
Bryant Jones
05-15-2002 10:25:57
Can anyone tell me the correct width for the Jubilee rear wheel rim, I am thinking either 9 or 10 inches. Does the Jubilee use the same width as the late 8N? I need a pair of the original type rims with the raised center that bolts to the wheel center piece. I have the later loop type and want to go back original. I also need a correct intake/exhaust manifold.
Scott
05-15-2002 19:30:20
 Re: Jubilee rear rims in reply to Bryant Jones, 05-15-2002 10:25:57
If you find an original rim it will be 9" that is the only 28" width they offered from 1939-1954.
buck
05-15-2002 19:08:32
On my NAA the 12.4 tires call for a 11 inch rim and a best I can measure it is 10 inches bead to bead and would be 11 inches out to out of rim. These are original hat section rims and have never had CC in them. Hope this helps.
bg
05-15-2002 19:43:40
 Re: Re: Jubilee rear rims in reply to buck, 05-15-2002 19:08:32
The 10" x 28" tire designation is now 11.2 x 28" for the N rim. I've seen lots of 12.4 and even some 13.something? on these rims.
buck
05-15-2002 19:55:32
 Re: Re: Re: Jubilee rear rims in reply to bg, 05-15-2002 19:43:40
where should the rim width be measured? At the bead or at full out to out. got my curosity up now. thanks
