Bad brakes
Ken Smith
05-13-2002 17:17:49
My 1947 8n runs great. However, I use a bushhog on very hilly terrain. Hyd fluid seeps out of the rear axile and I think has ruined the brakes. I have adjusted so that I have plenty of brake peddle. Do I need new pads?
How can I stop the hydraulic fluid from leaking out?
thanks,
ken
uh . . . Dell (WA)
05-13-2002 19:53:14
 Re: Bad brakes in reply to Ken Smith, 05-13-2002 17:17:49
Ken..... ....back in 1972, my ol'farmer neighbor and tractor mechanic mentor would get livid insisting DO NOT OVERFILL the N-tractor hydraulics because it would leak out the axle trumpets and ruin the brakes. He always insisted to pour out 1 qt of fluid out of the 5 gals bucket before pouring remaining into the tranny fill up by the tranny shifter. I am religious about that.
As to whether you need new brake shoes, I would, $50 cheap. Axle seals $6 cheap. Check your I&T FO-4 manual for procedure $29 cheap..... ....Dell
oops . . . Dell (WA)
05-13-2002 20:01:46
 Re: Re: Bad brakes in reply to uh . . . Dell (WA), 05-13-2002 19:53:14
happy trigger finger?
uh . . . Dell (WA)
05-13-2002 19:52:50
Rusty
05-13-2002 17:51:48
You need to replace the axle seal. The ford shop manual FO-4 helps.
