Order Ford 9N Parts Online
9N running bad
Erman
05-12-2002 02:52:53
low hours on engine since total rebuild. sounds like it's hitting on one cyl. It was sitting idling when whatever is wrong with it happened. I have checked compression, it's OK, changed manifold gasket, plugs, points, Distributor cap, rotor and carb.
Dell (WA)
05-12-2002 10:45:09
 Re: 9N running bad in reply to Erman, 05-12-2002 02:52:53
Erman..... ....what Rob said..... ..
Indescrimate parts replacement without a reason is poor shadetree mechanic-ing.
Based upon your description, "bad running", and since you do not report changing your square frontmount ignition coil, and since the frontmount ignition coil is not as robust as we'd like'em to be, and since there is no eazy shadetree mechanic test for a bad frontmount ignition coil.
REPLACE your frontmount ignition coil..... ...Dell
Rob
05-12-2002 06:50:57
If it's really hitting on only one cylinder when you short that plug wire to ground she will quit.
It sounds like someting moved. Timing. This is one of those cases where swapping parts adds little or nothing to troubleshooting.
It isn't backfiring and it runs so timing can't be too bad. You have to isolate this to fuel or electrical. Check the spark and swap plugs around to see if the problem moves. Start with the basics and step through it.
Good spark then make sure you're getting fuel. All that's good then timing. If your getting fuel and spark then it must not be happening at the right time. Post again then.
Fast Ed Ohio
05-12-2002 23:50:16
 Re: Re: 9N running bad in reply to Rob, 05-12-2002 06:50:57
You dont have the spark plug wires crossed , we all know better than that . ( Been there , done that, dont tell anyone ).1243
