Order Ford 9N Parts Online
9n no spark
Bri9n
11-16-2000 15:13:12
Here is the background:
-18 months ago put tractor in shed to redo the steering which was shot...got that done...tractor was generally running fine prior to, but battery didn't charge and it stalled when hot..always started fine
- while I had it in there I decided to redo the electrical, which had been modified at least partially to a 12 volt system with bastardized switches and wiring
- in the last couple months I have been working on it and replaced all the electical including cutout,resistor,battery,ignition switch, starter switch(not the starter though),cables, coil, spark plugs and wires, points, dist cap, condensor and rotor...to 6 volt system
-read posts and archives (educational and theraputic), learned basics of using a multimeter and am confident I have everything ok to the coil...also check points for shorting with ohmmeter and am ok there I believe based on advise from previous posts
-but I'm not getting spark at the plug...looking for suggestions in general and specifically how to diagnose further the coil/distributor
Thanks in advance
norm-wy
11-16-2000 16:37:58
 Re: 9n no spark in reply to Bri9n, 11-16-2000 15:13:12
Brian Did you remove the extra voltage dropping resistor which was probably on it from the 12V conversion.
You should see about 3.5 volts at the coil with the points closed and batt voltage (roughly 6 volts) when the points are open. If the extra resistor is still connected you may be seeing omly around 2 volts at the dist. HTH
Bri9n
11-16-2000 17:09:40
 Re: Re: 9n no spark in reply to norm-wy, 11-16-2000 16:37:58
I don't think there was a resistor before...I figured this is one reason the coil was not working properly before I replaced it....I do get battery voltage at the coil...but I think I've been checking it with the wire disconnected from the coil..would that matter?
Thanks.
norm-wy
11-16-2000 19:08:47
 Re: Re: Re: 9n no spark in reply to Bri9n, 11-16-2000 17:09:40
Brian
Yes it makes a big difference. If the wire isn't connected to the coil there is no current flow and with no current flow you will see batt voltage at the end of the wire all the time. Hook up the wire to the coil and then measure the voltage at that point both with points open and then closed. You should see about 3.5V with points
closed and batt voltage with the points open since there is no current flow when the points are open. HTH
Bri9n
11-18-2000 16:19:45
 Re: Re: Re: Re: 9n no spark in reply to norm-wy, 11-16-2000 19:08:47
Norm, thanks for the help...boy I still have a lot to learn about the electrical stuff...I checked the voltage with the wire connected to the coil and got battery voltage with the points open and closed...but I have the coil/distributor taken off the tractor...is that ok? I don't see how to open and close the points with the distributor on the tractor.
Thanks.
norm-wy
11-18-2000 16:31:59
 Re: Re: Re: Re: Re: 9n no spark in reply to Bri9n, 11-18-2000 16:19:45
Brian If you have batt volts at the coil both with points open and with them closed, you just think they are closing. Try cleaning & re-adjusting your point gap, reinstall the coil/dist and the just roll the N back or fwd, with it in gear, just enough to open and close the points and see if that gives you the correct readings. There is also a little spring that makes contact between the coil and dist. Clean it and make sure its making contract to the dist. HTH
Bri9n
11-19-2000 14:42:01
 Re: Re: Re: Re: Re: Re: 9n no spark in reply to norm-wy, 11-18-2000 16:31:59
Norm, thanks for the help...it helped to point me in the right direction..with further examination of the coil/distributor I found the spring at the bottom of the coil was not making good contact. Now have a nice blue spark and today the old girl ran for the first time in 18 months...Thanks from a happy tractor owner.
Brian.
Snow Plow
11-16-2000 16:24:07
For prior reference, when I good running hot engine stalls it is usually a coil problem. Let me guess, after it cooled off it started right up!
I can't help on spark problem. Everytime I get juice into the points, it comes out the other end. I'll be curious to see whats what!
Good Luck!
