Hi,Now I need help! My tractor is at a remote location in the high desert of California. We were out there today to do more work on it. It has a lot of sand, dirt and oil caked on to the major parts. Surprisingly, it ran well (until I started stripping it of parts). I am trying to replace things that are worn out, broken, or cost more in time to fix, then replace. The mixture of crud would be a cross of peanut brittle and brownies. I took HD Gunk and sprayer to clean. I must carry water as it isn't available; just Joshua Trees. Sorry, no rolling, lush meadows! I found that the Gunk didn't begin to penetrate the crud. I began to scrape some off and removed some parts for cleaning at home. Mainly, the air cleaner and carburetor. I can scrape most off the air cleaner, but I am concerned with the carburetor. I figure it would be best to buy a rebuild kit, right? Your comments would be appreciated on the best route to go for cleaning and repainting of the parts, except the carburetor. I found the air cleaner had everything intact, except the oil bath was a mix of oil and dirt. Thanks, Dick.
