Hi, just trying to fix up the botched wiring job on my 2N done by the previous owner...What I have now is the following: (6 volt pos ground system) 1. Battery Pos post is connected to ground bolt on Dash. (looks like a lighter weight 12 volt cable but the connection appears to be OK) 2. Battery Neg is connected to Starter switch post (Unit is located below the battery.) (This appears to be OK connection with lighter weight cables) 3. Starter is connected to other post on starter switch. 4. A wire runs from the starter switch (Paired with neg wire from battery) to 3rd post on resistor block. (Ammeter is bypassed completely) 5. The ignition switch, light switch, and connection to coil appear to be wired correctly.. The fun is that it appears that this guy had the generator wired directly to the resistor block. (NO CUTOUT RELAY).. Of course the insulation was wore off of the wire near the generator so it must have been shorting out, and the wire was unhooked under the dash before I bought the tractor, so I'm not sure where he had it connected. Just in case I'm looking in the wrong place.. Where on the tractor exactly should the cutout relay be positioned? (Pic anyone with a 2N? Please?) If it is missing in action as I suspect, I'll need to buy a new cutout relay, cause I'm sure haveing the generator wired directly to the battery probably is the reason that I found the battery significantly low on fluid when I got home...(boiling battery anyone ??) I've topped it up with distilled water, and I'm running a 6 volt trickle charger into it overnite to see if it will hold a charge. I'm going to try and connect up the ammeter to see if it is bad. If it doesn't work, I guess I'll set it aside and put it a temporary one from an auto parts store that fits the hole... for now. How much would an original ammeter cost? is it still a valid part available at local NH dealers? Anyone know the part no. for the ammeter ? Thanks in advance for your help with this folks... Lyle.
