Jumping Lift
duey in MN
05-01-2002 17:55:05
Last year, when bush hogging with '46 2N, the lift would occasionally take to jumping up & down when trying to keep the hog up a little ways. It's not 'operator induced'. Is this a worn linkage problem or perhaps a pump issue? Is this common to the ol' iron?
When I had the arms tied down to check the pump pressure recently, there was only minor leakage from the cylinder. The relief valve gave just under 1700 PSI. I've got fresh 134 oil in now. Any advice?
uh . . . Dell (WA)
05-02-2002 01:15:25
 Re: Jumping Lift in reply to duey in MN, 05-01-2002 17:55:05
Duey..... ...sounds like you need the $80 Zane Thang for your 2N..... .....Dell
DON TX
05-01-2002 19:44:24
I believe yuor cam follower pin is worn. Check the archives and IT Fo4 manual.HTH
DON TX
duey in MN
05-01-2002 21:42:15
 Re: Re: Jumping Lift in reply to DON TX, 05-01-2002 19:44:24
Thanks Don, I was thinking that was just an 8N thing, I'll check it out.
