Boxed up a BIG Part today!!!
Mark Hendershot
04-30-2002 09:25:06
It took a while but it can be done! I was able to box up a Jubilee Rear End Caseing in 1/2 inch thick card board and 2-lbs of duct tape and got it to excactly 150lbs. so it could go by UPS. Had to remove the trumpit studs and the guts to make it weight that much. So if you ever need one shipped by UPS it can be done. A bare block for a 8N will ship by UPS also. Mark H.
raytasch
05-01-2002 07:36:39
 Re: Boxed up a BIG Part today!!! in reply to Mark Hendershot, 04-30-2002 09:25:06
Mark, I am NOT trying to be a smart a$$ but would that center housing ship just cleaned up good and tagged? I have shipped some fairly big stuff unwrapped, nothing that big, and it did not have to be wrapped. Have the rules changed? ray
Mark Hendershot
05-01-2002 12:53:41
 Re: Re: Boxed up a BIG Part today!!! in reply to raytasch, 05-01-2002 07:36:39
That's a good question! I asked UPS and they told me it has to be clean and nothing sticking out to hurt the drivers when they pick it up. I like some padding around the gaskit sealing areas to protect them with. Mark H.
Ken in PA
04-30-2002 21:29:02
I don't believe you sould send a block! If I give you me address at work,would you prove it to me? I sure could use one :-)
Ken
DaBrow
05-01-2002 09:06:30
 Re: Re: Boxed up a BIG Part today!!! in reply to Ken in PA, 04-30-2002 21:29:02
I have shipped several bare 8N blocks in board crates & they do go UPS at under 150#. I believe it cost about $75 to ship from ME to CO. ...DaBrow
Mark Hendershot
04-30-2002 21:42:50
I would have it in the mail tomorrow if I had a 8N block. But now if you need a 134 cid Jubilee block I could help you out. I haven't weight that one yet I think it is over the 150 lb mark but real close. Mark H.
The Washington Tractor Magnate is at it again Huh? Ultradog MN
04-30-2002 18:56:14
Good going Mark.
There is a living to be made in these old tractors. Somewhere.
You're carving out a little corner of the market for yourself.
I'm glad for you.
Mark Hendershot
04-30-2002 22:13:49
 Re: Re: Boxed up a BIG Part today!!! in reply to The Washington Tractor Magnate is at it again Huh? Ultradog MN, 04-30-2002 18:56:14
Thank You Ultradog! I hope you are getting lots of work lately with all that nice weather you are having now. Mark H.
John,PA
04-30-2002 14:36:02
Hey Mark,
Was all that in 1 box? 150#?
Just curious. :{)
Mark Hendershot
04-30-2002 15:02:22
 Re: Re: Boxed up a BIG Part today!!! in reply to John,PA, 04-30-2002 14:36:02
The emptiy case with out the gears was 150 lb, one box. The rear gears 95lbs one box. I pack gears in spray foam after they are bagged up in plastic. That way they can go in a card board box and won't get damaged. I do the same thing to Crank Shafts. Blocks go on a piece of plywood with 2x2s under it so you can lift it. I bolt them to it with the pan holes and put plywood over the top of the block then cover it with card board and tape it up good with packing tape. Mark H.
Hey Ken! MikeC
04-30-2002 14:43:45
 Re: Re: Boxed up a BIG Part today!!! in reply to Ken N Tx, 04-30-2002 14:01:32
I used to work for USF Dugan (way back when it was TNT Dugan). Still have some friends at the Des Moines AF terminal. Get a reasonable discount with an LTL carrier and I bet AF could beat the UPS price. Dugan used to charge about $50 for 150#'s.
Mark Hendershot
04-30-2002 14:11:02
Problem is the rates at Fed-X, UPS would charge 78.00 and Fed-X 400.00 for the same part to the same place. Mark H.
How much does it cost to send?
04-30-2002 13:02:52
just curious
Mark Hendershot
04-30-2002 14:01:18
 Re: Re: Boxed up a BIG Part today!!! in reply to How much does it cost to send?, 04-30-2002 13:02:52
It was around 78.00 to go to Maine from Washington State. Mark H.
DavidO
04-30-2002 10:29:43
Thanks, that is good to know. I am always wanting to know if something will go by UPS or has to go freight. It is amazing that UPS will take some of these things.
Sounds like Cookie time to me.
Mark Hendershot
04-30-2002 14:08:30
 Re: Re: Boxed up a BIG Part today!!! in reply to DavidO, 04-30-2002 10:29:43
It is couch time! I just pounded 50 Steel T-Posts 2 ft in the ground in 4 hours. That is about 6 minuits per post and the last few took longer. I must be getting old. That did include cross wiring 3-H-Pulling Posts and laying the stakes out too. So maybe around 5 mins a post. Used to do 75 non stop must be getting old! Mark H.
Greg (NV)
04-30-2002 14:40:38
 Re: Re: Re: Boxed up a BIG Part today!!! in reply to Mark Hendershot, 04-30-2002 14:08:30
Hey Mark, you're braggin aren't ya. What were ya poundin-em in sand? LOL. If'n ya get the time I've got about a 200 foot section of fence I need to put in and I'd like to see ya do-em in this rock strewn ground we have. LOL again.
Greg
Nevada
Mark Hendershot
04-30-2002 14:55:41
 Re: Re: Re: Re: Boxed up a BIG Part today!!! in reply to Greg (NV), 04-30-2002 14:40:38
Greg; I know I counted the hits with the driver and it was about 30 to put one in. Nice ground no rocks but hard. It seemed that when it got down to around 2 ft it got easier to pound in. Can't brag I am so tired that's all I will do for the rest of the day! Mark H.
Greg (NV)
04-30-2002 15:00:52
 Re: Re: Re: Re: Re: Boxed up a BIG Part today!!! in reply to Mark Hendershot, 04-30-2002 14:55:41
Write back in the morning and let us know how the old body feels. Ya know, muscles ya didn't know ya had, etc. It's fun gettin young isn't it? I know I sure can't do what I used ta do. Can't even eat what I use to be able to and "THAT" really bothers me. I love food.
Greg
Nevada
