360 engine
Jim in Pa
04-24-2002 19:49:59
Has anyone heard of a 72 Ford 360 big block put in a ford tractor. I have aquired this engine with less than 15k miles on rebuild.Now I'm looking for a home for it. Thanks Jim in Pa
Jim in Pa
04-25-2002 09:54:10
 Re: 360 engine in reply to Jim in Pa, 04-24-2002 19:49:59
Ok then, 360 for sale, low milage on factory rebuild!!!
StuartK
04-25-2002 09:33:14
It's the 300 ft/lbs of torque you have to worry about! Just get a scattershield to mate it up and wear kevlar underwear for when the ring gear saws it's way out of the diff! StuK
Scott N Ky
04-25-2002 05:59:08
hmmmm, U planning on yanking caves out of the ground or pulling the bends out of rivers?
Gary in Missouri
04-25-2002 02:58:21
Let me know before you dump the clutch the first time so I can get in my storm celler to dodge the schrapnal.
Randy
04-24-2002 23:41:14
Jim: Far too much power, it's ridiculous. You'll break the tractor or your neck when it does that wheelie you weren't ready for.
duey in MN
04-24-2002 20:15:57
Question: You thinkin' this is a good matchup for that 30 HP transmission and rear end? Some folks can twist off the shafts with the 4 cylinder, ya know.
Truck
04-24-2002 20:15:17
Well, IF anyone has done it it would be Marvin Baumann. I'd sell it to somebody who needed it and go find a Funk instead to satisfy my HOP up urges. Probably justa little too much power and weight for an N.
