Order Ford 9N Parts Online
1940 9n loader attachment
chris
04-22-2002 17:07:06
I have found a front end loader to fit my 9n. All measurements seem to fit.My concern is weight?The whole assembly seems to hang from a bolt just below the pump shaft.Does this seem OK or should I be concerned?
don t. - 9n180179
04-23-2002 01:47:51
 Re: 1940 9n loader attachment in reply to chris, 04-22-2002 17:07:06
Im not 100% sure on some of this, maybe someone else can assist. I have a wagner on my toy. Bolts on to rear axles and a "plate" that connects loader to front of tractor. s/b 2 bolts?? Have crank mounted stinger pump for full hyd. I can take pics if needed. Don't know model # offhand.
"My concern is weight"...and it can be. Paraphrasing Dell(wa), 'n's aren't loader tractors, front ends are not built for it. That said, my needs required one. It is limited but I take my time, a little common sense, (knock wood) no problems.
HTH....don t. ....
T. TUTHEROW
10-18-2004 21:28:18
 Re: Re: 1940 9n loader attachment in reply to don t. - 9n180179, 04-23-2002 01:47:51
hope you can help me with my mounting problem, front end loader(wagner on 9N) would like to see how yours is mounted, what kind of bracket.
thanks
