Order Ford 8N Parts Online
8N Oil Pressure
Gary(WI)
04-21-2002 21:29:56
Just got My 8N running today but it doesn't have any oil pressure took out block where oil gauge hooks in and there is no oil at all with it running ( didn't leave it run for long!!!)
Also is it possible to have an 8N engine with a 9n/2n trans and diff.it has an 8N serial # but looks like 9N steering gear. Thanks for all the input.
Gary(WI)
04-23-2002 21:30:57
 Re: 8N Oil Pressure in reply to Gary(WI), 04-21-2002 21:29:56
Didn't just overhaul,but I bought it not running had been acouple of years since it was run, Thanks for the help!!!
Dell (WA)
04-22-2002 01:07:42
Gary..... ....8N blocks fit on 2N/9N's trannys 8N's had a tad more hp than 2N/9N's.
You scare me when you say "Just got My 8N running today but it doesn't have any oil pressure" Does that mean that you just rebuilt the engine and you don't have any oil pressure? If so, then you need to "prime" the oilpump with some greese (it will disolve in hot oil). This will require pulling the oilpan.
Some have reported success priming the oil pump by squirting a lot of oil back through the oil pressure relief bolt up by the water pump. I'd try that first before I bite the bullet an pull the oilpan..... .....Dell
