Order Ford 8N Parts Online
Lift dont work on 8N ?
david
04-20-2002 10:05:06
I just got the main pump installed and new o-ring installed on piston, but lift wont raise. is it possible i missed alignment with the lift control lever[the long rod on the top section] ? if correct, what must it engage or align to ?
Paul8n
04-20-2002 10:10:46
 Re: lift dont work on 8N ? in reply to david, 04-20-2002 10:05:06
Make sure PTO is engaged, don't ask. HTH
david
04-20-2002 10:59:31
 Re: Re: lift dont work on 8N ? in reply to Paul8n, 04-20-2002 10:10:46
i got it working, the lever was problem, had to unbolt top section and remove inspection plate and guide it in position. its working but not too great, jerky or erratic when lifting, whats possible cause of this ??
ZANE
04-20-2002 18:57:59
 Re: Re: Re: lift dont work on 8N ? in reply to david, 04-20-2002 10:59:31
Erratic lifting is usually caused by one or more of the four pumps not pumping. Could be a badly worn pump piston/cylinder or a bad valve in the pump head on one or both sides. Sometimes a valve spring will break and cause these symptoms.
