Learned a few things today.
Tom White
04-18-2002 15:53:57
Today the fields finally got dry enough to hook up the bush hog to the 8N and get to working on them. I spent about 5-6 hours on the N, with about the same amount yet to go. Same fields as always, same 8N, same me.
But geez, what a difference!
The differences were in three changes I had made while waiting for the ground to get dry enough to mow. A new proofmeter. New tires thta are air filled (the old ones were calcium chloride filled). And finally, a padded seat cover.
The proofmeter (my old one did not work) showed me that I had been running the throttle way too high. The tires filled with air were a much lighter pull on the tractor. The padded seat cover sure made it easier on my soon to be 51 year old hind end! Seriously, I could not believe how much easier and cooler the N ran, but I guess that is what doing things properly will do for it.
Anyhow, the fields look good, and the tractor and I are both happier.
Now if I could just finally figure out how to avoid sunburn! :)
Ed Gooding (VA)
04-19-2002 04:08:59
 Re: Learned a few things today. in reply to Tom White, 04-18-2002 15:53:57
Hi Tom. Here's one way that original owners avoided sunburn:
third party image
Here's another:
third party image
Most tractor supply places sell a universal fit umbrella that mounts to a rear fender, that would be comparable to one of the original solutions.
Hope this helps..... ..... Ed
'52 8N475798
rasputen
04-18-2002 18:18:05
Tom,
Due to having a lot of "Hedge Apple" trees (with thorns), I have learned to wear long sleeves and long pants. It cuts down on scars and blood. And helps keep the "spots" down on my arms. A long sleeve T shirt is protective and quite cool when you sweat. I also found I had been running way high on the RPM's when I bought a 641 w/proofmeter. My 8N is '47 build,(no P-Meter), and now I run it closer to 1500 RPM. Guestimating, but closer now.
Have fun, & play safe.
bd
Johnny
04-19-2002 07:03:09
 Re: Re: Learned a few things today. in reply to rasputen, 04-18-2002 18:18:05
Is "Hedge Apple" another name for Bois'd Arc?
Know some call them Horse Apple and Osage Orange, never heard Hedge Apple.
9N'er
04-18-2002 17:00:34
soon to be 51 year old hind end?
"...Anyhow, the fields look good, and the tractor and I are both happier.
Now if I could just finally figure out how to avoid sunburn! :) ..."
Just curious tho....where did you say you got sunburned? not on the soon to be 51 year old ____ ??
Fast Ed Ohio
04-18-2002 22:16:57
 Re: Re: Learned a few things today. in reply to 9N'er, 04-18-2002 17:00:34
I hope he dont say kiss my sunburn .
