12V Wiring diagram w/ 1-wire alternator?
Duke
04-17-2002 11:06:19
Anyone have a wiring diagram that shows the proper way to wire an 8N with a 12V conversion and a 1-wire alternator? I suspect mine has a short or was not wired right to begin with.
Had both the alternator and batt. tested. Both A-ok, except I have to recharge battery after using tractor 2 or 3 times, or else it won't start tractor.
Duke
Bill W.
04-17-2002 17:56:38
 Re: 12V Wiring diagram w/ 1-wire alternator? in reply to Duke, 04-17-2002 11:06:19
Duke: try this.
Dell (WA)
04-17-2002 12:31:27
Duke..... ....Most 1-wire 12 volt conversions take the alternator output and connect it directly to the big battery side of the 8N starter solenoid and that is it. Simple, no?..... ...Dell
And since you're dealing with a 1-wire alternator your have to rev your engine to about 2000 rpms to get the alternator to kick in. Which is why a lot of 12 volt converters use the 3-wire alternator with idiot light because you don't have to abuse your cold slow turning tractor engine to get your battery charge started after starting.
Duke
04-17-2002 12:39:01
 Re: Re: 12V Wiring diagram w/ 1-wire alternator? in reply to Dell (WA), 04-17-2002 12:31:27
This is how it is wired now with 1 wire from alt-battery. My battery is good (tested), alternatory is good (tested), but the lights won't work (bulbs ok), and the battery winds down after 2 or 3 times starting the tractor. Yes, I rev the engine up to get alternator going. What am I missing?
Jim WI
04-18-2002 11:17:19
 Re: Re: Re: 12V Wiring diagram w/ 1-wire alternator? in reply to Duke, 04-17-2002 12:39:01
CLUE:
"but the lights won't work"
I betcha there's at least one wire missing between two parts of the positive side of the electrics.
Dell (WA)
04-17-2002 19:59:29
Duke..... ....Obviously, if your battery discharges, it is NOT connected to your 1-wire alternator 12 volt output. Since the 1-wire alternator has built-in voltage regulator, you do NOT need anything to do with the OEM square voltage requlator on the backside of your dash panel. get rid of it!
Is your 3-terminal starter solenoid installed so the itty-bitty termanal is engine side and hard to get to? It goes to the big starter push button by the tranny shifter.
Sometimes people have replaced the 3-terminal tractor solenoid with a 4-terminal automobile starter solenoid. If you do that, all bets are off 'cuz I don't know how they rewired it.
If you are starting your engine, that implys that the big battery cable is going down to the starter solenoid battery terminal. AND THAT is where you MUST connect your alternator 12 volt charge output.
You do realize, unlike the OEM 6 volt positive ground system, the 12 volt alternator demands 12 volt battery NEGATIVE GROUND. Thing is the starter doesn't care, positive or negative ground, still turns the same direction. Just turns faster with 12 volts.
The starter solenoid big battery terminal should have 3 wires bolted to it. The bigg'un from the battery positive post. The long one from the 1-wire alternator. Then one up to the ignition key to turn on the ignition coil.
You could also hook-up your headlight switch to that same soleniod battery terminal because it is eazy. Do not wire your 30 amp headlights thru your 5 amp ignition switch. Unless you like to continually replace burned out ignition switches..... ..... .Dell,
who sez it really is simple to convert your 8N to a 1-wire 12 volt alternator UNLESS you are electrically challenged (grin)
Jack- Illinois
04-17-2002 15:55:26
I think it is time for a voltage check right at the output terminal of the alternator. After sitting for a while not running you should have 12 to 12.5 volts. After starting and reving engine it should be aroung the 14 volt level. If the voltage doesn't change the alternator is not working. An ampmeter could be wired in at the alternator output also. Hopes this helps. Jack
George8NFL
04-17-2002 11:54:52
can' get my pc to copy it but go to archieves at top. Go to authors, go to #6 (Brian in S IL)he has great postings. Good luck
Duke
04-17-2002 12:18:28
 Re: Re: 12V Wiring diagram w/ 1-wire alternator? in reply to George8NFL, 04-17-2002 11:54:52
Looked at Brian's pages but looks like he uses a 2-wire alternator (P1/P2 etc.) Thought maybe there was a diagram for 1-wire and does not use idiot light.
Jim WI
04-18-2002 11:13:45
 Re: Re: Re: 12V Wiring diagram w/ 1-wire alternator? in reply to Duke, 04-17-2002 12:18:28
It's called a 1-wire because it only needs 1-wire to work. That wire runs from the big BAT post on the back of the alternator to the positive post on the battery. The ground return is from the negative battery post through the engine block to the alternator mount. If you're worried about getting a good ground (happens sometimes), you can run an additional wire from the negative battery post to the frame of the alternator.
If the alternator isn't charging, try placing a wire from the BAT post on the alternator to either the P1 or P2 terminal. This is sometimes needed to get the field established. And lastly, if your alternator is spinning slower than it's designed for, goosing the throttle up temporarily can help start the alternator working (the standard alternator generally starts up better at low speeds because the idiot light circuit helps establish the field).
If you can't get the alternator to reliably start up without the jumper wire, you could add the idiot light circuit (according to a catalog for rebuilt alternators, the P1 and P2 terminals are still active on the 1-wire version).
Errin OH
04-17-2002 11:34:24
Heres the best I can do.
Alternator----- ----- ----- --Battery,
Check for proper rotation of the alternator, I am not sure if they will put out running in reverse. Mine (mid 70's marine 1 wire alt) turns clockwise and must be mounted on the left side of the tractor (53 NAA). If my memory servers 8n needs to be mounted on the right?????
Don, Luling LA
04-17-2002 21:05:08
 Re: Re: 12V Wiring diagram w/ 1-wire alternator? in reply to Errin OH, 04-17-2002 11:34:24
Changing what side the altenator is mounted on won't change the direction of rotation. The only way to change the direction of rotation is to mount the altenator with the pully facing the engine instead of facing foward.
Duke
04-17-2002 11:45:32
Is everything other than the batter--alternator connection the same as what is on the nseries wiring diagram?
Errin OH
04-17-2002 22:36:32
 Re: Re: Re: 12V Wiring diagram w/ 1-wire alternator? in reply to Duke, 04-17-2002 11:45:32
Pretty much. You no longer need the field (F) wire, just tape it off. The ground "G" to the old gen should be used as a good ground for the alt. I know that it should be grounded since its mounted to the block but I did it anyway. The Bat or Arm wire can be use for the output just move it under the dash to the hot side of the terminal block. The only other wiring mod will be the resistor in line with the coil if you use the 6v one.
I will add here that the Amp meter, if equiped, will now read backwards. Flipping the wires will fix it if its a big deal to ya.
I respectively disagree with the idea that you have to reve the engine up to get it going. That may be the case if the ratio between the crank pully and alt pulley is 1:1, if, as in my case 2.5:1 at 600 rpm the alt is turning 1500 and at 1200 shes a spining some 3000 rpm. Most alts start charging when the alt is turning 1200 rpm. And a mine charges just fine at idle.
A big Dooooop on the side thing I was really refering to the rotation of the engine. Some marine alts are made to fit counter rotating engines. I used an old marine alt and had to verify the rotation. I'll try to save some face and call it a test. Yea thats it, a test. Don ya passed with flying colors.
