3 pt backhoe
Hasch Yaeger
04-15-2002 19:26:50
I'm thinking of using a 3 pt backhoe on my 9N. Does anyone have experience with this? Can anyone recommend a size to use? How would this work out on that kind of tractor? Does anyone know where to look for one in south east Pa?
Hasch Yaeger
04-16-2002 17:59:07
 Re: 3 pt backhoe in reply to Hasch Yaeger, 04-15-2002 19:26:50
Thanks for the help fellows. I guess I will keep looking for an old case 480 backhoe or something similar. I think that sounds like the best thing to do.I still love the old 9N.
TomP
04-16-2002 13:47:58
While on the subject of backhoes has anyone had
experience with the Trencherman II? Sure sounds
good on the Northern Tool catalogue page. Almost
looks like fun.
http://www.northerntool.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=531&prmenbr=6970
Larry 8N75381
04-16-2002 10:06:34
Hasch,
I have a Woods BH750 that I use on my Ford 3000. It is VERY handy to have. It was expensive, but I would buy it again in a instant knowing what I do now.
I have seen one of the Kelly hoes (not sure which model, but a small one) on a small JD. It was a lot smaller than my Woods, and I would say it would be a good fit for an N series tractor. One issue that you should check is the top link rocker is not very deep and the top link of the hoe might hit the back of the rocker before the pin would go in. Also, the hoe puts a lot of PULLING load on the top link rocker which was designed for PUSHING loads. I say that because I BROKE the cast rocker on my 3000. Then I found out that you were susposed to replace the cast rocker with a steel weldment that Woods made just for the 3000.
Regards,
Larry
ED-IL
04-16-2002 03:56:31
I have never used one on my 2N, but I had done some research a while back. The link below will take you to a website with some three point hitch mounted backhoes, that have their own hyd reservoir and PTO driven pumps.
As Dell said, these get heavy because of the extra equiptment, with the ilghtest one listed at 550 pounds without a bucket. However, if I remember correctly, the N hydraulics in good working order can lift 800 pounds. So driving across the field with one of these on could make you feel like you were driving on the moon.
Dell (WA)
04-15-2002 22:57:31
Hasch..... ....most modern type 3-point backhoes are sub-frame mounted to the host tractor. N-Tractors don't have that ability. N-Hydraulics are a weak sister at about 2.5 gpm and 1500 psi. So you would need an external pto driven hydraulic pump about 10 gpm and 2500 psi and 25 gal resevior.
The N's front wheels start flapping in the breeze when you try to lift over 750# with the 3-point lift arms. I don't know how much a backhoe attachment weighs, but probably over 500#.
My advice, if you just gotta dig a trench, go rent a backhoe or hire a backhoe outfit. Experienced BHO's will save you alot of money and time.
You might want to check out CADPLANS.COM for some well engineered homemade backhoe plans if you can weld and get materials.
N's are great tractors, but they're not always the right tractor for a job..... .....Dell
Eddie
04-13-2004 14:25:13
 Re: Re: 3 pt backhoe in reply to Dell (WA), 04-15-2002 22:57:31
a buddy of mine needing to find out the weight of a 1970 Ford 4400 Backhoe/front end loader/scoop in the front/three(3) point/ thing ah meh jig...the nearest scales where he lives is about 3 miles..any one having any info..we would gr8tly appreciate it...thanks
