2N carb help
knuckel dragger
04-15-2002 15:10:48
My 2n seems to have carb problems. When giving it gas or when it starts to pull under a load and the governor calls for more fuel it will hesitate at best or stall. Is a rebuild in order or should I try something else? Thanks .
Dell (WA)
04-15-2002 16:02:55
 Re: 2N carb help in reply to knuckel dragger, 04-15-2002 15:10:48
One of the founding N-Board members used to claim 80% of all carburator problems were found and solved in the ignition system.
It's not unusual to find that the reason the engine hesitates under load is the distributor centrifical advance weights pivots are worn or springs missing too. I'd suggest removing the distributor (2 bolts) and inspecting the advance charisterics at a workbench. Parts are readily available for rebuild..... .....Dell
