2nd Gear, Stuck in with a twist
Gary-8n-fl
04-14-2002 12:29:58
OK, I'm adjusting the grade on the raod out front with the grader blade. Going reverse to first etc etc.
Well, 2nd gear has never worked on my 8n since I got it about a year ago. While shifting all the sudden I (pulling out of reverse 2 the second position on my way to first) feel 2nd engage. Great, musta knocked somthing loose.
Now the problem is the trans is stuck in 2nd but the shifter moves from 2nd to reverse (stalls the end if tried) through all neutral.
I have yet to pull the cover, but am wondering what could be wrong?
Thanks
doug vose
04-14-2002 18:21:30
 Re: 2nd Gear, Stuck in with a twist in reply to Gary-8n-fl, 04-14-2002 12:29:58
my guess is that one of the shifter forks fell off the slider gear and it is now stuck in reverse and second.
i have a AC model B that gets stuck in gear(s) like that, i have to take the forks off and line them up and put the forks back on, although i dont know if you can do that with a ford.
duey in MN
04-14-2002 13:13:28
Typical symptoms of a transmission when it has two gear positions engaged at the same time. That's my guess ... You'll need to pull the cover and get a look.
