49er will not start
Todd
04-13-2002 14:16:20
I know three things has to be working right for a engine to start...compression,fuel and spark.Compression in each cylinder is 110 lbs, fuel is full but no spark.Just put in plugs,points condesor and timing. everyhing checked out to be set right,by the way this a 12 volt 8n.Think maybe this is a coil?
steve MI
04-13-2002 18:05:15
 Re: 49er will not start in reply to Todd , 04-13-2002 14:16:20
A Long time ago, 1962 a old guy told me not to replace the condensor if a vehicle was running good, he said they are bad or good, A friend called me and said his car wouldn't start after he did what you did to your tractor, told him to put the old condenser back in and try it, he did and it ran, new one was bad, also look for grounding on the condensor wires and points wires, easy to touch a wire grounding them out, done it my self once or twice in 40 years
Steve IA
04-13-2002 15:32:09
Do you have spark to the top of the coil?
