Leaky cut-off valve
Larry, Mo.
04-13-2002 08:45:04
I am going to put a new cork gasket in a very leaky cut off valve on the 2N. I got to thinking maybe I don't put it together in the right order. I put the screen in place first, the cork gasket goes in next and then I put the sediment bulb in place. Am I correct that the screen goes up into the cut off valve first? As always, thanks for all your help.
Mark Hendershot
04-13-2002 09:06:09
 Re: Leaky cut-off valve in reply to Larry, Mo., 04-13-2002 08:45:04
That's how it goes together. Then you twist the glass bowl unto the gaskit as you tighted it up for a good seat. Mark H.
