Order Ford 8N Parts Online
8N wiring harness routing
Gary Beyer
04-10-2002 14:21:58
Can anyone describe the factory routing for the wiring harness on a late model 8N? Specifically, I'm wondering how the harnesss is routed down to the starter and generator from behind the dash.
Gary
MikeC
04-10-2002 14:49:05
 Re: 8N wiring harness routing in reply to Gary Beyer, 04-10-2002 14:21:58
The wiring going to the generator goes through the tube mounted on the top of the head. Unless you work and work and work and can't get the !!@$&%^ thing through the #%$^&^%^$ tube, then you can take some wire ties and kinda wrap them around the !!@#@#$ tube with the wiring on the outside of the !!@#$$% tube held in place by a very user friendly plastic wire wrap (can you guess that I had difficulty with the tube?) (GRIN)
Hope this helps.
