Order Ford 9N Parts Online
Adjusting the 9N Carb just to start it up?
Mark Hendershot
04-09-2002 21:40:56
I wanted to know what you set the carb adjustment screws at just to start it again. I am done with the engine and soon will get to fire it off again. I pulled all the adjustment screws out to clean the carb. It was easier to ask then look it up. I forgot what they were when I screwed them in and back counted for reseting them. If not I will get out the book and do some reading to get the answer. Thanks, Mark H.
Dell (WA)
04-09-2002 22:44:02
 Re: Adjusting the 9N Carb just to start it up? in reply to Mark Hendershot, 04-09-2002 21:40:56
Mark..... ....basic carb settings, 1 turn out both screws per Ford. I usually just set my main jet to 1 1/2 and leave it. I'd rather run rich than burn my valves..... ..... .Dell
Mark Hendershot
04-09-2002 22:52:13
 Re: Re: Adjusting the 9N Carb just to start it up? in reply to Dell (WA), 04-09-2002 22:44:02
Thanks Dell I will do just that!! I get to start it soon again. one last part my spring rod and it is in the mail. Read the post below did you know him at Boeing. Thanks Again, Mark H.
