Tommy..... ...how long were you gone fishing? Long enough for the battery to discharge back through the idiot light through the ignition coil through the closed ignition points? Happens all the time to GM and other cars. If you are starting and running your car/truck/tractor every day, you haven't run down your battery down enough to make it a non-starter so you never notice. I know of 7 ways to convert to 12 volts, some of them work better than others (grin). While I usually recommend the "idiot light" scheme on 12 volt conversions, its got its problems as you have found out. The idiot light/marker light "decouples" or reduces the available power to the ignition coil so it won't sustain hot enought sparkies to keep the engine running and then the engine dies when you turn off the ignition key. I like the 3-wire 12 volt conversion, because it causes the alternator to charge at the low RPM's that our N's run at. I don't like the 1-wire conversion, while quite popular for a lot of 12 volt conversions, it doesn't charge well at low tractor RPM's. Somehow, I don't think your description matches the usual 12 volt Delco SI-10 conversion scheme. I don't think your white wire should go to ground. The Red wire usually has an "idiot light" in line to the ignition switch "on" terminal. Usually pin 2 (remote sense) white wire is hardwired right at the alternator to the big battery charge stud which is usually hardwired to the battery stud on the starter solenoid for convience. The #1 (excite) red wire usually has the idiot light in it to the ignition switch "on" terminal which also goes to the ignition coil. And naturally, your 12 volt battery is negative grounded. Starter doesn't care positive or negative ground. Alternator does care, the internal "diodes" absolutely require negative ground or else they turn into expensive semi-conductor fuses. Ammeter semi-cares positive ground/negative ground. If it shows negative when you know the alternator is charging the battery, just reverse the ammeter connectons. Traditionally, ammeter show "+" when battery is being charged and traditionally "+" is to the right of the meter scale..... ..... ...HTH, Dell
