Order Ford 8N Parts Online
1952 8N starter
George
04-07-2002 16:23:30
Got the starter off and had it reworked. Having a time getting it to go back in. I have ordered manuals but wanted to see if someone could help give me a hint on which way to hold the starter (or my mouth) while trying to get the starter drive unit back in.
George
04-08-2002 04:49:12
 Re: Re: 1952 8N starter in reply to Ed Gooding (VA), 04-08-2002 03:41:44
Thanks to all for the help. I will grind out the hole just enough to get the gear drive in and this will fix my problem. Til next problem!!!!
Greg
04-07-2002 19:34:55
 Re: 1952 8N starter in reply to George, 04-07-2002 16:23:30
George, When you had your starter re worked, was a new style Bendix installed? Some older Ns require some grinding of the case for the new style bendix to clear. This was explained to me by a New Holland parts man.
John,PA
04-07-2002 16:28:37
I don't know any "tricks" to gett'n the starter back into the casting except to take your time and tilt the starter as close to the engine block as you can, while aligning the starter casting to the bolts.
