Order Ford 8N Parts Online
8n timing trouble
glenn
11-09-2000 19:04:13
recently plowing a feild my 8n just stoped dead no spark. replaced the points and now it just backfires.I one weeek ago i change from the six volt coil to a 12v/12v convertion.It has a front mounted dist.I have replaced points befor but never had this problem.I thought you couldnt get the dist in wrong due to the offset on the drive
slot. Or can it be 180 degeres off???any help please.
Dell (WA)
11-10-2000 10:27:28
 Re: 8n timing trouble in reply to glenn, 11-09-2000 19:04:13
Glenn..... .."no spark. replaced the points and now it just backfires".....
Even new points slip their gap and narrow down which reduces the sparkies and causes backfires and non-running. Check your points gap.
One other "helpful hint", check your voltage to the 12 volt frontmount coil. With the the generator charging, 13.0 MAX allowed, most 12 volt generators/alternators charge about 14.7 volts. This translates to about 11 volts with the points closed and the engine "off". Any higher voltage will burn out your new 12 volt frontmount ignition coil. See if you can find the correct value of external resistor in the frontmount coil instruction sheet somewhere and use it!!! ..... ....Dell
Salmoneye
11-10-2000 05:48:22
It is very difficult (next to impossible) to get the front-mount distributor on 180 degrees off without breaking something.
Sounds like you traded whatever problems you had with the 6-volt for a different set with the 12-volt.
Check the archives. You will find that about half of the posts on this board deal with 12-volt conversions and why not to do them...
