Order Ford 8N Parts Online
8N GRILL REMOVAL
DON TX
04-06-2002 13:13:21
Trying to get the grill off? How are the clips at the top supposed to move? I don't want to bend anything. My trusty FO-4 don't say a thing about grill's. And how does it come out? Lift or bolt? TIA DON TX
Barnstormer
04-06-2002 13:26:50
 Re: 8N GRILL REMOVAL in reply to DON TX, 04-06-2002 13:13:21
The clips with the pin attached move straight downward. A pair of pliers should do the trick. You may have to jiggle the grill a little bit.
THANKS---DON TX
04-06-2002 13:43:46
 Re: Re: 8N GRILL REMOVAL in reply to Barnstormer, 04-06-2002 13:26:50
NT
Barnstormer
04-06-2002 13:49:55
 Re: Re: Re: 8N GRILL REMOVAL in reply to THANKS---DON TX, 04-06-2002 13:43:46
Don, you mentioned the clips and that was all that I responded about. To take the grill out completely, loosen or remove the bottom dogleg bolts. HTH
DON TX
04-06-2002 14:24:32
 Re: Re: Re: Re: 8N GRILL REMOVAL in reply to Barnstormer, 04-06-2002 13:49:55
Yeah, figured it out after the grill tilted. If I get these comp. test readings figured out I'll be able to tell which way to go. DON TX
