2n front spindle
Charles Parker
04-05-2002 19:54:23
Fellas and gals,please help an OLD southern boy with a front spindle guestion .This is my 1st. tractor and I've just learned how to check the oil .Question,when I raised the front end there is a lot of play(up&down)with the spendle. Took them apart found 4,5 bushings lower bearings,and key.Is there maybe an adjustment ? Thanks YAW'LL .
Tim k
04-05-2002 20:06:24
 Re: 2n front spindle in reply to Charles Parker, 04-05-2002 19:54:23
I really don't understand your explantation of what you found. Anyway, there is no adjustment. There is a lower bearing which the spindle rides on and there are 2 bushings in the axle housing, that's it. If there is a lot of up down movement, I suspicion that it either is the lower bearing, or the top arm that has moved (I doubt it is the top arm since that is not only keyed, but also pinned with the bolt that tightens it. And that's my $.02
