2n wiring
sonoffo
04-02-2002 12:08:00
After much help from you gentlemen, I finally got my 2n running pretty well.Thanks. Now, I have a question. My 2n was changed over to a 12V. system a few years back. In the process of fixing it, I replaced the 6volt coil with a 12 volt type. Do I still need the two pronged reducer or can I just run the coil wire directly? Will this burn the points or anything else, and why? I have another reducer that I purchased for $17 (has three screws), but haven't installed it yet. What's the point? Do I need one? two? or can I now just run the wire straight. Thanks for everything
Phil (AZ)
04-03-2002 05:02:01
 Re: 2n wiring in reply to sonoffo, 04-02-2002 12:08:00
Sonoffo,
The front mount Coil is prone to overheating and here are some numbers that suggest you need protection for 12V Coils.
Watts = (V X V)/R
Normal 6V Coil with the Correct Ballast Combo for 6V or 12V Operation
(2.6 X 2.6)/.8 = 8.45 Watts (Worst Case) Key left on and points closed.
Operating (3.0 X 3.0)/.8 = 11.25 watts with a 38 % duty Cycle = ~ 4.27 watts.
(This Coil should last electrically for a lifetime)
The 12V Coil ( 12.5 X 12.5) /2.5 = 62.5 Watt(Worst Case) Key left on and points closed.
Operating (14.5 X 14.5)/2.5 = 84.1 watts with a 38 % duty Cycle = ~ 31.95 watts
The 12V Coil with a Ballast of .5 to.75 Ohms.
(10.5 x 10.5) /2.5 = 44.1 watts with a 38 % duty Cycle = ~ 16.75 watts
I would say that you cannot leave the Key �ON� with a 12 V coil but how much heat (watts), before it fails, will be determined by users (MTBF). We do know that if you bypass the ballast on a normal 6V Coil it will fail, and these are those numbers.
(6.5 X 6.5) /.8 = 52.8 Watts (Worst Case) Key left on and points closed.
Operating (7.2 X 7.2) /.8 = 64.8 Watts with a 38 % duty Cycle = ~ 24.62 watts
Hope this Helps,
