2N Crank
Gene
11-08-2000 16:12:14
If any of you fine folks have your 2N service manual handy look up the standard size for the connecting rod journals on the crank for me. I will be helping my brother in law with the rebuild on his 2N and need this info to help us assess the condition of the crank. He has a manual (cheeep) but he probably can't find it quick enough. Thanks for a wonderful board! Gene
Mark B (PA)
11-08-2000 19:22:57
 Re: 2N Crank in reply to Gene, 11-08-2000 16:12:14
The FO-4 lists Crankshaft journal diameter as 2.248-2.249 in. (57.10-57.12mm) and the crankpin diameter as 2.094 in (53.18mm) HTH
Gene
11-08-2000 19:39:29
 Re: Re: 2N Crank in reply to Mark B (PA), 11-08-2000 19:22:57
Thanks for the response Mark. My brother in law's tractor is apart and we can't order parts until we verify that the crank is useable. I love this board even though my tractor is an AC model B. The data base represented here is incredible!
Gene.
