1953 ford carb adjustment
j. hankinson
03-28-2002 17:14:05
having problems leaning out carb on 1953 ford tractor.
rebuilt carb, new wires, plugs, coil, cap, totor.
still running rich.
Dell (WA)
03-30-2002 11:09:36
 Re: 1953 ford carb adjustment in reply to j. hankinson, 03-28-2002 17:14:05
I've let this post for others more intimately familiar with the M/S carb used on the '53 NAA to answer because it is somewhat different from the M/S TSX-241B used on the 8N's that I am more familiar with.
Things for you to check. Carb venturi can sometimes be installed upsidedown
Jets can sometimes be incorrectly interchanged. FYI....idle jet is 0.025
FYI....main jet is #49 drill
As I said, I am not an expert on NAA carbs..... .Dell
