Hello all, please help!I've read the 1200 or so posts and Zanes advice on R&R'ing the hydraulic system for an 8N. Mine has Fickle hydraulics - sometimes they'd lift right up and sometimes not. If they would lift, they would not stay (drift down). Last weekend I watched the video 3 times, read the manual and proceeded to drain the fluid, drop the pump and clean it up (outlet valves), replaced the safety valve & put new fluids & gaskets in. Things I didn't do: 1) check the cam follower pin (I don't know why, I just forgot!) 2) did not disassemble & clean intake & check valves on pump. Results: 1) Still may or may not lift. 2) If it lifts and then I drop it, it takes a minute or 2 before it lifts again. 3) Usually holds (doesn't drop) if it does lift, but not always (argh!) 4) I have leaks around pump plate on trans housing. I guess I didn't put the bolts back in the right order - does anyone know the sequence of short/long bolts??? Final question - I've read the posts here about taking the inspection cover off and checking what the pump is doing. I've done this again and again, but I can't see any of the valves for they are all submerged in transmission fluid? Is this right or not? How low/high should the fluid be? I put in 5 gallons. Any ideas? What else should I check? Thanks for any help! Bob - 1949 8N
